How to develop game using LAN framework
This category will guide you on how to develop your own game
Postby flashman » 26 Dec 2012, 10:22
If you are a game developer, this is the place where you'll find the best multiplayer game framework - LAN framework.
You can create Flash and html5 multiplayer games fast and easy using our Java based LAN framework.
Your game can run in desktop computer and also in any mobile device (iPad, iPhone, android phone, etc..).
The framework is made for big enterprise projects (games) but it could be used also for medium or small games.
Using LAN framework you will take care of ONLY writing your game logic.
Everything else (such as: lobby game schedule, connections, threads, synchronization, tables and all the framework features) is supported by the framework so you don't have to spend additional time writing it.
But before you begin, you have to choose whether you want to creage game for yourself or for LAN.bg portal
If you create a game for LAN.bg portal then you will have profits of this, based on how good your game is.
In this case LAN framework will give you the following set of build-in features:
  1. Playing in multiple tables at same time
  2. "Quick seat" module
  3. Lobby individual tables
  4. Broken game support
  5. Game watchers support
  6. Translations support
  7. Tournaments support
  8. "Auto answer" timers
  9. Artificial Intelligence support
  10. Full logging support
  11. Many portal features like: Messages, friends, statistics, facebook integration, profits, invite feature, lobby chat, smiles, memes, etc..
If you decide to create game for yourself, then you will have full control of your game, you can post it in facebook, in your site, you can even create your own game portal. It is up to you.
In this case the LAN framework will give you the following set of build-in features:
  6. "Auto answer" timers
  7. Artificial Intelligence support
  8. Full logging support
  9. Full control and customizations of the game
So, what would it be?
How to create a game for my site - Hello World example
How to create a game for my site - Tic Tac Toe example
OR
How to create a game for LAN.bg portal (soon)
flashman
Return to Game Development
Who is online
Users browsing this forum: No registered users and 1 guest
cron
